These examples can be found in the EXAMPLES subdirectory of your Eagleware installation (commonly C:\Eagle or C:\Program Files\GENESYS). The header of each example section is the filename. The required RAM is the value estimated by EMPOWER. They are approximate and are determined by algorithm rather than a test of memory used. The execution times are for a 266 MHz Pentium II with 256Mbytes of RAM operating under Windows 98. In most cases execution time is for the discontinuity mode. When different run options are used during the example the time and RAM listed are for exercise options with the longest time and largest memory requirement. The following extra examples are provided for your reference, but are not included in the Examples manual.
