homebridge示例插件示例集合
消耗积分:0 | 格式:zip | 大小:0.08 MB | 2022-04-21
王玉兰
分享资料个
授权协议 Readme
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
homebridge-examples
This repo bundles some example implementations for homebridge plugins. They provide some example code to get started with. They are also published on npm like regular plugins, so you can easily run them in your local homebridge instance. Refer to the respective package.json for the plugin name and install them as usual.
The examples are all written in Typescript and thus require at least homebridge v1.0.0.
To build a plugin run the following commands in the respective plugin directory.
Run this command once to install all dependencies required by the plugin:
npm install
After that run the following command to compile the Typescript files into Javascript (repeat this step every time you change something in the code).
npm run build
If you need inspiration for a plugin written in Javascript you can just run the above commands and look at the generated Javascript code located in the ./dist folder. You may need to ignore some code at the beginning of the file generated by the Typescript compiler.
Examples for different homebridge plugin types
Accessory Plugins
Accessory plugins are the most basic and simplest plugins for homebridge. They should be used if you only want to expose a single accessory and don't require any special functionality.
Platform Plugins:
Platform plugins are able to expose multiple accessories. Additionally, they are required if you want to use the Controller API.
  • Static Platform Plugin: Static platforms know which accessories they want to expose on start up. The set of accessories cannot change over the lifespan of the plugin.
  • Dynamic Platform Plugin: Dynamic platforms can dynamically add or remove accessories at runtime. Accessories are fully stored to disk by homebridge, and the exact state is reconstructed on a reboot. The plugin can store additional context as well.
  • Independent Platform Plugin: Independent platforms are typically used when the platform intends to only expose external accessories or provides other functionality while not exposing an accessory at all.
Other example plugins
评论(0)
发评论
下载排行榜
