外观检验标准 APPEARANCE INSPECTION CRITERIA
6.1 Motorola的表面等级 MOTOROLA SURFACE CLASSIFICATION
表面等级 ”AA”, “A”, “B”, “C”, ” D” 的外观允收判定标准依指定的表面标准执行,标准请参考本文件的6.3。
The acceptability of the appearance for surfaces classified “AA”, “A”, “B”, “C” or “D” is determined by the criteria for its designated surface class as defined in Section 6.3 of this specification.
6.2 Motorola 表面等级标准 MOTOROLA SURFACE CLASS CRITERIA
一个面有多个缺陷时,该面的总缺陷尺寸由所有缺陷的尺寸累积值确定。
Multiple imperfections on a single surface must have the sizes of the individual imperfections added together to cumulatively determine the total defect size for that surfac声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
