Ultra-Low Noise Low Dropout (LDO)
Voltage Regulator IC
Total Solutions for Powering Precision Analog Applications
The TPS7A30 LDO paired with the positive voltage TPS7A49 LDO provides designers with a total solution for powering precision analog applications. The LDOs feature ultra-high power supply rejection ratio (PSRR) performance and as low as 16 µVRMS of output noise. The TPS7A30 LDO generates -200 mA, while the TPS7A49 LDO supplies 150 mA. The LDOs are designed for noise sensitive applications.
