TLC272,TLC272A,TLC272B,TLC272Y,TLC277,pdf(LinCMOS precision dual operational amplifiers)
消耗积分:10 | 格式:rar | 大小:1050 | 2010-09-16
1123127317
分享资料个
The TLC272 and TLC277 precision dual operational amplifiers combine a wide range of input offset voltage grades with low offset voltage drift, high input impedance, low noise, and speeds approaching those of general-purpose BiFET devices.
These devices use Texas Instruments silicon-gate LinCMOS™ technology, which provides offset voltage stability far exceeding the stability available with conventional metal-gate processes.
The extremely high input impedance, low bias currents, and high slew rates make these cost-effective devices ideal for applications previously reserved for BiFET and NFET products. Four offset voltage grades are available (C-suffix and I-suffix types), ranging from the low-cost TLC272 (10 mV) to the high-precision TLC277 (500 uV).
评论(1)
发评论
zyq158 2020-09-22
0 回复 举报
很好 收起回复
下载排行榜
全部1条评论
