SLE4442/SLE4432 pdf datasheet
消耗积分:10 | 格式:rar | 大小:666 | 2008-09-22
分享资料个
The memory is organized in a Main Memory of
· 64 byte for SLE 4440
· 128 byte for SLE 4441
· 256 byte for SLE 4432 and SLE 4442
Each of the first 32 bytes of the Main Memory can be irreversibly protected against data change
by writing the corresponding bit in the Protection Memory (32 bit). Dependent on the state of the
protection bit the memory is read only (ROM) or may be erased and written again (EEPROM).
Change of the manufacturer code is only possible by the chip manufacturer.
Change of data of the Main Memory and write a bit of the Protection Memory is only possible
after a correct verification of the Programmable Security Code (PSC) for SLE 4440, SLE 4441
and SLE 4442.
评论(0)
发评论
下载排行榜
