MAX9622 ,pdf (宽带运算放大器)
消耗积分:10 | 格式:rar | 大小:433 | 2010-10-02
分享资料个
The MAX9622 op amp features rail-to-rail output and 50MHz GBW at just 1mA supply current. At power-up, this device autocalibrates its input offset voltage to less than 100µV. It operates from a single-supply voltage of 2.0V to 5.25V.
The MAX9622 is available in a tiny 2mm x 2mm, 5-pin SC70 package and is rated over the -40°C to +125°C automotive temperature range.
关键特性
  • 50MHz UGBW
  • Low Input Voltage Offset Voltage (100µV max)
  • Input Common-Mode Voltage Range Extends Below Ground
  • Wide 2.0V to 5.25V Supply Range
  • Low 1mA Supply Current
  • 应用/使用
    工业系统ADC驱动器
    汽车电源
    滤波器
    仪表
    电源模块
    更多宽带运算放大器:http://www.elecfans.com/soft/special/kuandaifangdaqi/
    评论(0)
    发评论
    下载排行榜
