The DG2714 is a single-pole/double-throw monolithic CMOS analog switch designed for high performance switching of analog signals. Combining low power, high speed (tON: 28 ns, tOFF: 12 ns), low on-resistance (rDS(on): 0.85 Ω) and small physical size (SC70), the DG2714 is ideal for portable and battery powered applications requiring high performance and efficient use of board space. The DG2714 is built on Vishay Siliconix’s low voltage submicron CMOS process. An epitaxial layer prevents latchup. Break-before -make is guaranteed for DG2714. Each switch conducts equally well in both directions when on, and blocks up to the power supply level when off.
