dg9411 pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-09-28
分享资料个
DESCRIPTION
The DG9411 is a single-pole/double-throw monolithic CMOS
analog switch designed for high performance switching of
analog signals. Combining low power, high speed (tON: 9 ns,
tOFF: 5 ns), low on-resistance (rDS(on): 7 Ω) and small
physical size (SC70), the DG9411 is ideal for portable and
battery powered applications requiring high performance
and efficient use of board space.
The DG9411 is built on Vishay Siliconix’s low voltage JI2
process. An epitaxial layer prevents latchup. Break-before -
make is guaranteed for DG9411.
Each switch conducts equally well in both directions when
on, and blocks up to the power supply level when off.
评论(0)
发评论
下载排行榜
