SSL2101/SSL2102 12W mains dimm
消耗积分:5 | 格式:rar | 大小:322 | 2010-10-31
分享资料个
The SSL2101/2102 12 W LED driver is a solution for a professional application with
multiple high power LEDs that requires galvanic isolation and a safe output voltage. It is
mains dimmable for both forward phase (TRIAC) dimmers, and reverse phase (Transistor)
dimmers. It can generate up to 16 W output power, which is equal to a 100 W
incandescent lamp (at 63 Lumen/W). Examples are shelf lighting, down lighting, LED
lighting for bathrooms etc.The design gives an example of how to make a drive that is
suitable for small form factor applications like retrofit lamps.
评论(0)
发评论
下载排行榜
