To test the superiority of software radio platform,a design adopting coherent detection demodulation 2FSK signal based on software radio is proposed. According to principles of modulation and demodulation 2FSK,the design used Matlab/Simulink software module to structure model,set parameters of each module and simulated in the software. The model source code generated co-simulation downloaded to the software radio platform. Coherent demodulation requires synchronization,so that the demodulation devices becomes relatively complicated. The circuit design signal which is through the software simulation and the sending signal are the same, The hardware co-simulation verification signal and the sending signal is also the same. The results prove the circuit is accurate and reliable,and it can achieve the desired effect.
