ARM系统中DMA方式在数据采集中的应用
消耗积分:10 | 格式:rar | 大小:970 | 2010-12-07
李敏
分享资料个
讨论了ARM系统中DMA通道的工作原理,并利用DMA技术设计了基于S3C2410和FPGA的CCD相机采集系统,给出了数据采集接口设计方案,以及Linux操作系统下接口的设备驱动程序。测试结果表明系统工作稳定,数据采集速率可以达到4 MHz。
Abstract:
 The principle of DMA in the ARM system is discussed, and a CCD camera acquisition system using the DMA technology is designed based on S3C2410 and FPGA.The design of interface and device driver in Linux operation system is presented. The experiment shows that the system is steady and the rate of sampling is 4MHz.
评论(0)
发评论
下载排行榜
