MAX8790高效率白色发光二极管(WLED)驱动器是专门针对采用LED阵列作为光源的大屏液晶显示器(LCD)而设计的。介绍了MAX8790的引脚功能、工作原理及典型工作电路。
- Abstract:
- MAX8790 is a high-efficiency driver for white light-emitting diodes. It is designed specially for large liquid crystal displays (LCDs) that employ an array of LEDs as the light source. The pin description, operation principle and operating circuit of MAX8790 are introduced in this paper.
