基于dSPACE的发电机实时控制系统研究
消耗积分:10 | 格式:rar | 大小:5311 | 2010-12-14
李霞
分享资料个
采用dSPACE单板系统DS1104试验平台的离散事件励磁变换器系统与连续时间双绕组发电机系统解耦的实时仿真方法,建立基于DS1104平台的双绕组感应发电机的实时控制模型,对一台双绕组感应发电机系统进行建压、变速试验研究,试验结果良好。
Abstract:
 The decoupling real-time simulating method of discrete event excited converter system and continuous time dual stator-winding generator system based on dSPACE DS1104 is proposed.The real-time control modern of dual stator-winding generator based on DS1104 is set up.The real-time simulating researches including voltage build up,variable speed of dual-stator winding induction generator are presented. The satisfactory effects are acquired.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
