PLC和触摸屏在继电器测试台中的应用
消耗积分:5 | 格式:rar | 大小:1913 | 2010-12-17
分享资料个
 铁路安全继电器是铁路系统中的重要执行元件,必须定期对其电气特性进行检查。针对继电器诸多型号对线圈电源高测量精度、宽动态范围的要求,开发一种继电器测试台。该测试台主要采用PLC作为主控元件,触摸屏作为人机界面,能对多种常用继电器的主要特性进行自动测试。
Abstract:
 Railway safety relay is the important implementing element in the rail system, and the electrical properties must be periodically measured. In order to satisfy the needs of many types of? Coil Power Relay against high accuracy, wide dynamic range, a relay tester has been developed. The tester adopts PLC as the major control components, touch screen as a Human and Machine Interface(HMI). Most of the properties could be automatically tested.
评论(0)
发评论
下载排行榜
