基于CPLD控制的声信号发射系统设计
消耗积分:5 | 格式:rar | 大小:651 | 2010-12-24
48674
分享资料个
 介绍了一种声信号发射系统的设计方案,系统是基于CPLD产品XC2C128控制,并通过EPROM(M27C64A)实现了波形存储,信号经D/A转换器(AD5330)、功率放大器(MAX9703)和变压器输出。另外,可通过改变存储器内波形存储的编码方式或存储器的型号和容量,实现时分复用(TDM)、频分复用(FDM)和码分复用(CDM)。经多次实验验证了该系统的可行性和扩展性。
Abstract:
 An acoustic signal transmission system is designed which is controlled by CPLD XC2C128.The waveform is stored by EPROM M27C64A,and the signal can be transmitted through the D/A converter(AD5330),power amplifier(MAX9703)and transformer.In addition,TDM,FDM and CDM can also be used in this system by changing the coding method or the type and capacity of the memory.The system has been verified the feasibility and expansibility by means of many experi-ments.
评论(0)
发评论
下载排行榜
