CMOS相机控制及图像数据传输系统设计
消耗积分:3 | 格式:rar | 大小:425 | 2010-12-24
分享资料个
介绍了相机控制接口与数字图像传输系统的设计方案,该系统是以EP2S30为传输通道控制核心实现基于PCI板卡的数字图像传输,采用FPGA模块设计和简洁的PCI9054中断控制,电路结构紧凑,功能完善,下载的图像质量较高。
Abstract:
 The camera controlling interface and digital image data transmission system are introduced in this paper.The digital image data transmission system based on PCI board is designed,which uses EP2S30as controller core.FPGA module designing and simply PCI9054interrupt controlling are used.The whole circuit is compact in structure and perfect in function,and the downloading images are in high quality.
评论(0)
发评论
下载排行榜
