基于数字信号处理的动态信号分析系统应用广泛并具有重要作用。利用TI公司高性价比的数字信号处理TMS320F2812设计了一种便携式态信号分析仪,该系统信号分析仪可采集动态信号,并处理数据的频域,可直接在LCD上显示信号各分量频率值、功率值、失真度等。通过实验测试,该动态信号分析仪简便直观,只要接收到信号源,即可观察信号的多种指标参数。
- Abstract:
- The dynamic signal analysis system based on digital signal processing has been applied to various fields and played an important role.On this basis,a set of dynamic signal analysis system is designed by using high cost-effective digital signal processor TMS320F2812DSP.The system can acquisite dynamic signal and process data in the frequency domain,then directly display the value of the signal component of frequency and power,distortion on the LCD.The experiments results show the dynamic signal analysis system is easy to use.As long as the received signal source is applied,a variety of indicators of the signal is displayed
