介绍了高频链逆变器的拓扑,建立了高频链逆变器及其重复控制策略的仿真模型,并对系统进行仿真分析。通过仿真验证了重复控制策略能够使高频链逆变器获得高质量的输出波形。
- Abstract:
- Topology of high-frequency line inverter is introduced.The model of repetitive control strategies for high-frequency line inverter is established,and the system is simulated.The simulation results show that the high quality waveform of the high-frequency line inverter can be gained by repetitive control technique.
