基于AT89S52的机载电气盒测试仪的设计
消耗积分:5 | 格式:rar | 大小:554 | 2010-12-28
分享资料个
飞机电网故障时,机载电气盒必须在延迟时间内切断电网,保护机载设备。采用AT89S52设计的电气盒测试仪能够测试电气盒保护功能,测量延迟时间。实际应用结果表明,该测试仪具有测量准确、可靠性高、成本低等优点。
Abstract:
 The helicopter-electrical-box must shut off the helicopter power,protect the equipments of the helicopter when the helicopter power is failed.The tester for the helicopter-electrical-box based on AT89S52is used for testing the protect-ing function and measuring the delay time.Application results show this tester has some advantages,such as accurate mea-surement,high dependability,economical cost etc.
评论(0)
发评论
下载排行榜
