In order to effectively detect and gather the fluorescence signals of the dental pulp of the tooth,the technology of laser induced fluorescence is used.The gather and display circuit of the fluorescence signals are designed,the ADS7804converters and the AT89C51are used as the core of the system,TFT-LCD is used as the display terminal,a fluorescence signal gathering system basea on the single-chip is designed.With the algorithm idea of sampling data mapping coordi-nate,dental pulp fluorescence signals are processed,display terminal is controlled through the single-chip microcomputer communication interface,in order to finish display of fluorescence signals.The gather and display of fluorescence signals of the dental pulp of the tooth is finished by system
