基于可编程器件的任意进制计数器的设计
消耗积分:10 | 格式:rar | 大小:634 | 2010-12-29
张虎豹
分享资料个
采用可编程器件设计电路,利用MAX+plus II设计软件中LPM元件库所提供的lpm_counter元件,实现任意进制计数器的设计。该计数器电路与结构无关,可编程器件的芯片利用率及效率达到最优,加快复杂计数器设计进程,减少调试时间,优化系统设计。
Abstract:
 The design module-N counter is realized by using programming device designing circuit,and the lpm_counter in the component library,LPM of MAX+plusII programming software.The counter circuit is independent of the circuit structure,and the utilization and efficiency of the programmable devices is maximized.This design method is available to speed the complicated counter design,reduce debugging time,and optimize the system design.
评论(0)
发评论
下载排行榜
