基于SiGe HBT工艺的GNSS接收机混频器设计
消耗积分:5 | 格式:rar | 大小:624 | 2011-01-04
王静
分享资料个
针对目前国内RFIC发展比较滞后的现状,设计了3款应用于GNSS接收机的基于0.5μm SiGe HBT工艺的混频器(Ⅰ、Ⅱ、Ⅲ),并采用针对混频器的优良指数FOM(figure-of-merit)对这3个混频器进行结构和综合性能比较。3款混频器的供电电压为3.3V,本振LO输入功率为-10dBm,其消耗总电流、转换增益、噪声系数、1dB增益压缩点依次为:Ⅰ)8.7mA,15dB,4.1dB,-17dBm;Ⅱ)8.4mA,10dB,4.6dB,-10dBm;Ⅲ)5.4mA,11dB,4.9dB,-10dB
Abstract:
 Aiming at the status of domestic RFIC development lags behind at present,three mixers(Ⅰ,Ⅱ,Ⅲ)for GNSS receiver based on0.5μm SiGe HBT process technology were designed and researched.These mixers were compared both in structure and comprehensive performance which is related to FOM(figure of merit).The three mixers with3.3V supply and-10dBm in-put LO power can obtain values of dissipation current,conversion gain,noise figure,1dB gain compression point as follows:(Ⅰ)8.7mA,15dB,4.1dB,-17dBm;(Ⅱ)8.4mA,10dB,4.6dB,-10dBm;(Ⅲ)5.4mA,11dB,4.9dB,-10dBm.While the FOM of the mixers were-57.8,-56.6,-54.3.It demonstrates that the comprehensive performance of mixerⅠis good,mixerⅡis better and mixerⅢis the best.
评论(0)
发评论
下载排行榜
