安全栅KFD2-STC4-EX1-Y1 现货直发
型号: KFD2-STC4-EX1-Y1
--- 产品参数 ---
公司logo
上海冠宁科技发展有限公司
1.5k內容 |  20w+浏览量  |  38粉丝
--- 产品详情 ---
参数表节选:的技术参数  KFD2-STC4-Ex1-Y1
General specifications
Signal typeAnalog input
Functional safety related parameters
Safety Integrity Level (SIL)SIL 2
Supply
ConnectionPower Rail or terminals 14+, 15-
Rated voltage20 ... 35 V DC
Ripplewithin the supply tolerance
Power dissipation1.4 W
Power consumption1.8 W
Input
Connection sidefield side
Connectionterminals 1+, 2-, 3 or 5-, 6+
Input signal0/4 ... 20 mA
Voltage drop≤ 2.4 V at 20 mA (terminals 5, 6)
Input resistance≤ 64 Ω terminals 2-, 3 ; ≤ 500 Ω terminals 1+, 3 (250 Ω load)
Available voltage≥ 16 V at 20 mA terminals 1+, 3
Output
Connection sidecontrol side
Connectionterminals 7+, 8-
Output signal0/4 ... 20 mA (overload > 25 mA)
Ripplemax. 50 µA rms
External supply (loop)11 ... 30 V DC
Transfer characteristics
Deviationat 20 °C (68 °F), 0/4 ... 20 mA
≤ 10 µA incl. calibration, linearity, hysteresis, loads and fluctuations of supply voltage
 Influence of ambient temperature0.25 µA/K
Frequency rangefield side into the control side: bandwidth with 0.5 Vpp signal 0 ... 7.5 kHz (-3 dB)
control side into the field side: bandwidth with 0.5 Vpp signal 0.3 ... 7.5 kHz (-3 dB)
Settling time200 µs
Rise time/fall time20 µs
Galvanic isolation
Output/power supplyfunctional insulation, rated insulation voltage 50 V AC
Indicators/settings
Display elementsLED
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 61326-1:2013 (industrial locations)
Conformity
Electromagnetic compatibilityNE 21:2011
Degree of protectionIEC 60529:2001
Protection against electrical shockUL 61010-1:2012
Ambient conditions
Ambient temperature-20 ... 60 °C (-4 ... 140 °F)
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 200 g
Dimensions20 x 124 x 115 mm (0.8 x 4.9 x 4.5 inch) , (W x H x D) housing type B2
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
Data for application in connection with hazardous areas
EU-type examination certificateBAS 99 ATEX 7060 X
 Marking
Ex-Hexagon
II (1)G [Ex ia Ga] IIC ,
Ex-Hexagon
II (1)D [Ex ia Da] IIIC ,
Ex-Hexagon
I (M1) [Ex ia Ma] I
 Input[Ex ia Ga] IIC, [Ex ia Da] IIIC, [Ex ia Ma] I
Supply
 Maximum safe voltage250 V (Attention! The rated voltage can be lower.)
Equipmentterminals 1+, 3-
 Voltage Uo25.4 V
 Current Io86.8 mA
 Power Po551 mW
 Internal capacitance Ci12 nF
 Internal inductance Li0 mH
Equipmentterminals 2-, 3
 Current Io/Current Ii74 mA / 115 mA
 Current Ii115 mA
 Voltage Uo3.5 V
 Current Io74 mA
 Power Po64 mW
Equipmentterminals 1+, 2 / 3-
 Voltage Ui30 V
 Current Ii115 mA
 Voltage Uo25.4 V
 Current Io115 mA
 Power Po584 mW
Equipmentterminals 5-, 6+
 Voltage Ui30 V
 Current Ii115 mA
 Voltage Uo8.7 V
 Current Io0 mA
CertificateTÜV 99 ATEX 1499 X
