--- 产品参数 ---
查看更多参数
公司logo
深圳市众泰电子有限公司
18內容 |  1.8w浏览量  |  8粉丝
--- 产品详情 ---
HT1622/HT1622G
RAM Mapping 32x8 LCD Controller for I/O MCU
(专利权核准)
(HT1622 44QFP 限用产品 )
(HT1622 52-pin QFP 封裝产品终止)
(HT1622 44QFP 封裝产品终止)
HT1622 is a peripheral device specially designed for I/O type MCU used to expand the display capability. The max. display segment of the device are 256 patterns (32x8). It also supports serial interface, buzzer sound, watchdog timer or time base timer functions. The HT1622 is a memory mapping and multi-function LCD controller. The software configuration feature of the HT1622 make it suitable for multiple LCD applications including LCD modules and display subsystems. Only three lines are required for the interface between the host controller and the HT1622. The HT162X series have many kinds of products that match various applications.
  • Features
  • Operating voltage: 2.7V~5.2V
  • Built-in RC oscillator
  • 1/4 bias, 1/8 duty, frame frequency is 64Hz
  • Max. 32x8 patterns, 8 commons, 32 segments
  • Built-in internal resistor type bias generator
  • 3-wire serial interface
  • 8 kinds of time base or WDT selection
  • Time base or WDT overflow output
  • Built-in LCD display RAM
  • R/W address auto increment
  • Two selectable buzzer frequencies (2kHz/4kHz)
  • Power down command reduces power consumption
  • Software configuration feature
  • Data mode and Command mode instructions
  • Three data accessing modes
  • VLCD pin to adjust LCD operating voltage
  • 44/52/64-pin LQFP packages
    HT1622G: Gold bumped chip
--- 数据手册 ---
