TDA2052.pdf
消耗积分:0 | 格式:pdf | 大小:121 KB | 2011-09-21
分享资料个
The TDA2052 is a monolithic integrated circuit in Heptawatt package, intended for use as audioclass AB amplifier in TV or Hi-Fi field application.Thanks to the wide voltage range and to the highout current capability it’s able to supply the highestpower into both 4W and 8W loads even inpresence of poor supply regulation.
评论(0)
发评论
下载排行榜
