AD0809英文
消耗积分:1 | 格式:pdf | 大小:264KB | 2014-06-26
erin
分享资料个
关于ad0809的详细资料,英文版
General Description The ADC0808, ADC0809 data acquisition component is a monolithic CMOS device with an 8-bit analog-to-digital converter, 8-channel multiplexer and microprocessor compatible control logic. The 8-bit A/D converter uses successive approximation as the conversion technique. The converter features a high impedance chopper stabilized comparator, a 256R voltage divider with analog switch tree and a successive approximation register. The 8-channel multiplexer can directly access any of 8-single-ended analog signals. The device eliminates the need for external zero and full-scale adjustments. Easy interfacing to microprocessors is provided by the latched and decoded multiplexer address inputs and latched TTL TRI-STATE® outputs. The design of the ADC0808, ADC0809 has been optimized by incorporating the most desirable aspects of several A/D conversion techniques. The ADC0808, ADC0809 offers high speed, high accuracy, minimal temperature dependence, excellent long-term accuracy and repeatability, and consumes minimal power. These features make this device ideally suited to applications from process and machine control to consumer and automotive applications. For 16-channel multiplexer with common output (sample/hold port) see ADC0816 data sheet. (See AN-247 for more information.)
Features n Easy interface to all microprocessors n Operates ratiometrically or with 5 VDC or analog span adjusted voltage reference n No zero or full-scale adjust required n 8-channel multiplexer with address logic n 0V to 5V input range with single 5V power supply n Outputs meet TTL voltage level specifications n Standard hermetic or molded 28-pin DIP package n 28-pin molded chip carrier package n ADC0808 equivalent to MM74C949 n ADC0809 equivalent to MM74C949-1 Key Specifications n Resolution 8 Bits n Total Unadjusted Error ±1⁄2 LSB and ±1 LSB n Single Supply 5 VDC n Low Power 15 mW n Conversion Time 100 µs
AD0809英文
评论(0)
发评论
下载排行榜
