直流牵引供电系统线路检测与自动重合闸的配合
消耗积分:0 | 格式:rar | 大小:168 | 2009-08-10
分享资料个
在直流牵引供电系统中,馈线断路器在合闸前及故障跳闸后重合闸前,需经过线路检
测回路对线路进行非短路确认后才能合闸。本文阐述了线路检测及其与自动重合闸配合的原理,并介绍了直流牵引馈线的保护配置。根据运营实例,说明了线路检测在馈线保护中的作用,对其在运行中暴露出的整定及与自动重合闸配合问题进行了分析,并提出了解决方案。
关键词:直流牵引供电系统;线路检测;自动重合闸;Profibus—DP;继电保护
Abstract: In DC traction power supply system, after line detection can not found short circuit, feeder circuit breaker can be closed. The principle of line detection with automatic re-closing was discussed and DC traction feeder relay protection is introduced. According to representative example, the application of line detection with automatic re-closing and problems, which was found in work, was analyzed, and a solutions was put forward.
Key words : DC traction power supply system; line detection; automatic re-closing;
Profibus—DP;relay protection;
评论(0)
发评论
下载排行榜
