高效高功率闪光灯设计技巧
消耗积分:1 | 格式:PDF | 大小:191KB | 2017-04-12
黄桂强
分享资料个
高效高功率闪光灯设计技巧
  Although the xenon lamps dominate the standard camera market, they are not applicable in the portable phone. As a matter of fact, the large reservoir capacitor and high voltage associated with the xenon flash make such a concept not suitable for the cellular phone equipments. The semiconductor based White LED devices provide the right choice when limited flash light becomes necessary to illuminate a photographic scene. This paper depicts the basics of the xenon concept and details a typical White LED flash application. XENON LAMP CONCEPT A low pressure of a rare gas mixture fills a glass envelope with two ends electrodes on both sides. In steady state, the voltage across the electrodes is set to a value well below the trigger voltage as depicted Figure 1. At this point, no current flows and the system is stable until a trigger voltage is applied to the third electrode. This high voltage pulse, in the 1 kV range, comes from a transformer built with a small magnetic tore triggered by an abrupt discharge of the capacitor C2 (see Figure 2).
评论(0)
发评论
下载排行榜
