自定义播放器XLVideoPlayer详解
消耗积分:1 | 格式:rar | 大小:0.3 MB | 2017-09-26
分享资料个
  AVPlayer:可以理解为播放器对象,灵活性好,可以高度化的自定义UI,但它本身不能显示视频,显示需要另一个类AVPlayerLayer来显示,继承于CALayer,下面是摘自官方的一段介绍:
  AVPlayer works equally well with local and remote media files.
  You can display the visual content of items played by an instance of AVPlayer in a CoreAnimation layer of class AVPlayerLayer.
  You can observe the status of a player using key-value observing.
  主要是说它支持本地/网络媒体播放,需要CoreAnimation下的AVPlayerLayer来显示视频,我们可以通过KVO监听player的播放状态。
  AVPlayerItem:存有相关媒体信息的类,一个视频资源对应一个AVPlayerItem对象,当你需要循环播放多个视频资源时也需创建多个AVPlayerItem对象。建议大家可以多看看官方的英文文档解释(题外话)。
  An AVPlayerItem represents the presentation state of an asset that’s played by an AVPlayer object, and lets you observe that state.
  AVAsset:主要用于获取多媒体信息,可以理解为一个抽象类,不能直接使用,操作针对它的子类AVURLAsset,根据你视频的url创建一个包含视频媒体信息的AVURLAsset对象。
  CMTime:还会用到这个媒体时间相关的类,如有不明白可以看之前一个帖子的解释。
  层级关系:
  基于以上几个类就能实现视频的基本功能了,例如暂停、播放,快进、后退、显示播放/缓冲进度。然后UI层面,层级很简单,XLVideoPlayer继承于UIView,上面我们说到显示视频需要AVPlayerLayer,我们将AVPlayerLayer加到view的layer上。
  下面贴出主要的代码,初始化AVPlayer对象
  - (AVPlayerLayer *)playerLayer {
  if (!_playerLayer) {
  _playerLayer = [AVPlayerLayer playerLayerWithPlayer:self.player];
  _playerLayer.backgroundColor = kPlayerBackgroundColor;
  _playerLayer.videoGravity = AVLayerVideoGravityResizeAspect;//视频填充模式
  return _playerLayer;
  - (AVPlayer *)player{
  if (!_player) {
  AVPlayerItem *playerItem = [self getAVPlayItem];
  self.playerItem = playerItem;
  _player = [AVPlayer playerWithPlayerItem:playerItem];
  [self addProgressObserver];
  [self addObserverToPlayerItem:playerItem];
  return _player;
  //initialize AVPlayerItem
  - (AVPlayerItem *)getAVPlayItem{
  NSAssert(self.videoUrl != nil, @“必须先传入视频url!!!”);
  if ([self.videoUrl rangeOfString:@“http”].location != NSNotFound) {
  AVPlayerItem *playerItem=[AVPlayerItem playerItemWithURL:[NSURL URLWithString:[self.videoUrl stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]]];
  return playerItem;
  }else{
  AVAsset *movieAsset = [[AVURLAsset alloc]initWithURL:[NSURL fileURLWithPath:self.videoUrl] options:nil];
  AVPlayerItem *playerItem = [AVPlayerItem playerItemWithAsset:movieAsset];
  return playerItem;
  同时我们注册KVO,监控视频播放过程,这可以获取视频的播放进度。AVPlayer有一个属性currentItem是AVPlayerItem类型,表示当前播放的视频对象。
  #pragma mark - monitor video playing course
  -(void)addProgressObserver{
  //get current playerItem object
  AVPlayerItem *playerItem = self.player.currentItem;
  __weak typeof(self) weakSelf = self;
  //Set once per second
  [self.player addPeriodicTimeObserverForInterval:CMTimeMake(1.0, 1.0) queue:dispatch_get_main_queue() usingBlock:^(CMTime time) {
  float current = CMTimeGetSeconds(time);
  float total = CMTimeGetSeconds([playerItem duration]);
  weakSelf.progressLabel.text = [weakSelf timeFormatted:current];
  if (current) {
  // NSLog(@“%f”, current / total);
  weakSelf.slider.value = current / total;
  if (weakSelf.slider.value == 1) { //complete block
  if (weakSelf.completedPlayingBlock) {
  weakSelf.completedPlayingBlock(weakSelf);
  }else { //finish and loop playback
  weakSelf.playOrPauseBtn.selected = NO;
  [weakSelf showOrHidenBar];
  CMTime currentCMTime = CMTimeMake(0, 1);
  [weakSelf.player seekToTime:currentCMTime completionHandler:^(BOOL finished) {
  weakSelf.slider.value = 0.0f;
  以及监听AVPlayerItem对象的status/loadedTimeRanges属性变化,status对应播放状态,loadedTimeRanges网络缓冲状态,当loadedTimeRanges的改变时,每缓冲一部分数据就会更新此属性,可以获得本次缓冲加载的视频范围(包含起始时间、本次网络加载时长)
  #pragma mark - PlayerItem (status,loadedTimeRanges)
  -(void)addObserverToPlayerItem:(AVPlayerItem *)playerItem{
  //监控状态属性,注意AVPlayer也有一个status属性,通过监控它的status也可以获得播放状态
  [playerItem addObserver:self forKeyPath:@“status” options:NSKeyValueObservingOptionNew context:nil];
  //network loading progress
  [playerItem addObserver:self forKeyPath:@“loadedTimeRanges” options:NSKeyValueObservingOptionNew context:nil];
  在这获取视频的总时长,网络的视频缓冲进度,做相应的显示。
  - (void)observeValueForKeyPath:(NSString *)keyPath ofObject:(id)object change:(NSDictionary *)change context:(void *)context{
  AVPlayerItem *playerItem = object;
  if ([keyPath isEqualToString:@“status”]) {
  AVPlayerStatus status = [[change objectForKey:@“new”] intValue];
  if(status == AVPlayerStatusReadyToPlay){
  self.totalDuration = CMTimeGetSeconds(playerItem.duration);
  self.totalDurationLabel.text = [self timeFormatted:self.totalDuration];
  }else if([keyPath isEqualToString:@“loadedTimeRanges”]){
  NSArray *array = playerItem.loadedTimeRanges;
  CMTimeRange timeRange = [array.firstObject CMTimeRangeValue];//本次缓冲时间范围
  float startSeconds = CMTimeGetSeconds(timeRange.start);
  float durationSeconds = CMTimeGetSeconds(timeRange.duration);
  NSTimeInterval totalBuffer = startSeconds + durationSeconds;//缓冲总长度
  self.slider.middleValue = totalBuffer / CMTimeGetSeconds(playerItem.duration);
  // NSLog(@“totalBuffer:%.2f”,totalBuffer);
  //remove loading animation
  if (self.slider.middleValue 《= self.slider.value) {
  self.activityIndicatorView.center = self.center;
  [self addSubview:self.activityIndicatorView];
  [self.activityIndicatorView startAnimating];
  }else {
  [self.activityIndicatorView removeFromSuperview];
  下面这部分是定位视频的某个位置播放,也就是快进后退。
  这里需要注意的是在用户拖拽slider的过程中需要先暂停,否则手动改变进度和播放的进度会有冲突,用户拖拽完毕再去播放视频。
  - (void)finishChange {
  _inOperation = NO;
  [self hiden];
  CMTime currentCMTime = CMTimeMake(self.slider.value * self.totalDuration, 1);
  [self.player seekToTime:currentCMTime completionHandler:^(BOOL finished) {
  [self.player play];
  self.playOrPauseBtn.selected = YES;
评论(0)
发评论
下载排行榜
