基于RFSA3413下的5MHz to 6000MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:1.58 MB | 2018-07-25
吴湛
分享资料个
  RFSA3413
  5MHz to 6000MHz, Digital Step Attenuator
  The RFMD’s RFSA3413 is a 4-bit digital step attenuator (DSA) that features high linearity over the entire 15dB gain control range with 1.0dB steps. The RFSA3413 uses parallel control interface. The RFSA3413 has a low insertion loss of 1.4dB at 2GHz. Patent pending circuit architecture provides overshoot-free transient switching performance. The RFSA3413 is available in a 3mm x 3mm QFN package.
评论(0)
发评论
下载排行榜
