基于TQM776011下的Multi-mode (WCDMA B1 / CDMA BC6 / HSPA+ / LTE) 3x3mm PA Module
消耗积分:0 | 格式:pdf | 大小:0.19 MB | 2018-07-25
分享资料个
  Product Description
  The TQM776011 is fully matched Power Amplifier Module designed for use in WCDMA UMTS Band 1, CDMA BC6 (IMT) & LTE handsets. Its compact 3x3mm package including a coupler and built-in voltage regulator makes it ideal for today’s extremely small data enabled phones. Its RF performance meets the stringent linearity requirements for multi-mode operation. The TQM776011 is designed on TriQuint’s GaAs BiHEMT technology with CuFlip® assembly offering state of the art reliability, temperature stability and ruggedness. The 3-Gain state PA die operates in LPM, MPM and HPM to maximize talk time over the entire range of operating conditions. To simplify the cost/time of calibration while in production the TQM776011 can be used in 1-bit operation; either LPM/HPM with only 4mA of IcQ up to +13dBm in LPM, or MPM/HPM with 9mA of IcQ up to +17dBm in MPM.
评论(0)
发评论
下载排行榜
