基于TQM756014下的Multi-Mode (WCDMA B4 CDMA BC15 HSPA+ LTE) 3x3 Module
消耗积分:0 | 格式:pdf | 大小:0.20 MB | 2018-07-25
笑尽往事
分享资料个
  Product Description
  The TQM756014 is fully matched Power Amplifier Module designed for use in CDMA BC15 (AWS), WCDMA (Bands 4) and LTE handsets. Its compact 3x3mm package including a coupler and built-in voltage regulator makes it ideal for today’s extremely small data enabled phones. Its RF performance meets the stringent linearity requirements for multi-mode operation. The TQM756014 is designed on TriQuint’s GaAs BiHEMT technology with CuFlip® assembly offering state of the art reliability, temperature stability and ruggedness. The 3-Gain state PA die operates in LPM, MPM and HPM to maximize talk time over the entire range of operating conditions. To simplify the cost/time of calibration while in production the TQM776011 can be used in 1-bit operation; either LPM/HPM with only 4mA of IcQ up to +13dBm in LPM, or MPM/HPM with 9mA of IcQ up to +17dBm in MPM.Features GaAs BiHEMT / CuFlip® PA Technology  Typical Quiescent Current values: LPM: 4 mA MPM: 9 mA HPM: 90 mA  Excellent Linearity in all modes  Integrated high performance coupler  Excellent Phase Discontinuity  Built-in voltage regulator functionality eliminating any external switch circuitry  Small 10-pin, 3x3mm module  Lead-free 260°C / RoHS / Halogen-free  Full ESD protection
评论(0)
发评论
下载排行榜
