基于TQM879006A下的1.4 −2.7 GHz ¼ W Digital Variable Amplifier
消耗积分:0 | 格式:pdf | 大小:1.12 MB | 2018-07-25
分享资料个
  Applications
  • 3G / 4G Wireless Infrastructure
  • CDMA, TD-CDMA, WCDMA, LTE
  • Repeaters • PTP Radio IF Chains
  Product Features
  • 1.4-2.7 GHz Frequency Range
  • 31.7 dB Maximum Gain at 2 GHz
  • 31.5 dB Gain Range in 0.5 dB Steps
  • +43 dBm Output IP3
  • +24.5 dBm Output P1dB
  • 1.5 dB Noise Figure at Max. Gain State
  • Fully Internally Matched Module
  • Integrated Blocking Capacitors, Bias Inductors
  • 3-wire SPI Control Programming
  General Description
  The TQM879006A is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range. The amplifier module features the integration of a low noise amplifier gain block, a digitalstep attenuator (DSA), along with a high linearity ¼W amplifier. The module has the added features of integrating all matching components with bias chokes and blocking capacitors. The internal DSA offers 0.5 dB step, 6-bit, and 31.5 dB range and is controlled with a serial periphery interface (SPITM)。 The TQM879006A features variable gain from 0 dB to 31.7 dB at 2 GHz, has +43 dBm Output IP3, and +24.5 dBm P1dB.
  The amplifier also has a very low 1.5 dB Noise Figure (at maximum gain) allowing it to be an ideal DVGA for both receiver and transmitter applications. The amplifier operates from a single +5V supply and is available in a compact 28-pin 6x6 mm leadless SMT package.
  The TQM879006A is pin compatible with the TQM829007 (0.6-1GHz, 0.25W DVGA) and TQM879008 (1.5-2.7 GHz, 0.5W DVGA)。 This allows one to size the right type of device for specific system level requirements as well as making the DVGA family ideal for applications where a common PCB layout is used for different frequency bands.
评论(0)
发评论
下载排行榜
