基于TQM879028下的0.7−4.0 GHz ½ W Digital Variable Gain Amplifier
消耗积分:0 | 格式:pdf | 大小:1.25 MB | 2018-07-25
无人岛
分享资料个
  Applications
  3G / 4G Wireless Infrastructure 
  Repeaters 
  LTE / WCDMA / CDMA
  Product Features
  0.7−4.0 GHz Frequency Range
  32 dB Maximum Gain at 2.14 GHz
  31.5 dB Gain Range in 0.5 dB Steps 
  +44 dBm Output IP3 
  +27.5 dBm Output P1dB 
  3-wire SPI Control Programming
  General Description
  The TQM879028 is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range. This amplifier module integrates a gain block, a digital-step attenuator (DSA), and a high linearity ½ Watt amplifier into a compact 4 x 4 mm module. The internal 6-bit DSA provides a 31.5 dB gain control range in 0.5 dB steps, and is controlled with a serial periphery interface (SPITM)。 The individual stages are accessible to external ports to allow for optimization of the last stage amplifier for individual bands and also allowing other functional blocks to be added in-between the stages. The TQM879028 features variable gain from 0.5 dB to 32 dB at 2.14 GHz, +44 dBm output IP3, and +27.5 dBm P1dB while only consuming 230 mA current from a 5 V supply. The module is available in a compact 24-pin 4 x 4 mm leadless SMT package.
评论(0)
发评论
下载排行榜
