ADS8410,pdf (16-Bit, 2-MSPS, L
消耗积分:0 | 格式:rar | 大小:1392 | 2010-06-03
hxjq
分享资料个
The ADS8410 is a 16-bit, 2-MSPS, analog-to-digital (A/D) converter with 4-V internal reference. The device includes a capacitor based SAR A/D converter with inherent sample and hold.
The ADS8410 also includes a 200-Mbps, LVDS, serial interface. This interface is designed to support daisy chaining or cascading of multiple devices. A selectable 16-/8-bit data frame mode enables the use of a single shift register chip (SN65LVDS152) for converting the data to parallel format.
The ADS8410 unipolar single-ended input range supports a differential input swing of 0 V to +Vref.
The nap feature provides substantial power saving when used at lower conversion rates.
The ADS8410 is available in a 48-pin QFN package.
评论(0)
发评论
下载排行榜
