Tag-it™ HF-I 方形标准Inlay [
消耗积分:0 | 格式:rar | 大小:73 | 2010-06-30
分享资料个
DESCRIPTION
Texas Instruments Tag-it™ HF-I standard transponder inlays consist of 13.56-MHz high-frequency (HF)
transponders that are compliant with the ISO/IEC 15693 and ISO/IEC 18000-3 global open standards. These
products offer a user-accessible memory of 256 bits, organized in eight blocks, and an optimized command set
available in five different antenna shapes, with frequency offset for integration into paper, PVC, or other
substrates.
The Tag-it HF-I standard transponder inlays are manufactured with TI’s patented laser tuning process to provide
consistent read performance. Prior to delivery, the transponders undergo complete functional and parametric
testing, in order to provide the high quality that customers have come to expect from TI.
The Tag-it HF-I standard transponder inlays are well suited for a variety of applications including, but not limited
to, product authentication, library, supply-chain management, asset management, and ticketing/stored value
applications.
评论(0)
发评论
下载排行榜
