LM107QML pdf,LM107QML datashee
消耗积分:0 | 格式:rar | 大小:666 | 2008-09-06
131594
分享资料个
LM107QML Operational Amplifier
General Description
The LM107 is a complete, general purpose operational amplifier,
with the necessary frequency compensation built into
the chip. Advanced processing techniques make the input
currents a factor of ten lower than industry standards such
as the 709. Yet, they are a direct, plug-in replacement for the
709, LM101A and 741. The LM107 offers the features of the
LM101A, which makes its application nearly foolproof. In
addition, the device provides better accuracy and lower
noise in high impedance circuitry. The low input currents also
make it particularly well suited for long interval integrators or
timers, sample and hold circuits and low frequency waveform
generators. Further, replacing circuits where matched
transistor pairs buffer the inputs of conventional IC op amps,
it can give lower offset voltage and drift at a lower cost.
Features
n Offset voltage 3 mV maximum over temperature
n Input current 100 nA maximum over temperature
n Offset current 20 nA maximum over temperature
评论(0)
发评论
下载排行榜
