CD40110B,pdf(CMOS Decade Up-Do
消耗积分:0 | 格式:rar | 大小:425 | 2010-08-10
分享资料个
CD40110B is a dual-clocked up/down counter with a special preconditioning circuit that allows the counter to be clocked, via positive going inputs, up or down regardless of the state or timing (within 100 ns typ.) of the other clock line.
The clock signal is fed into the control logic and Johnson counter after it is preconditioned. The outputs of the Johnson counter (which include anti-lock gating to avoid being locked at an illegal state) are fed into a latch. This data can be fed directly to the decoder through the latch or can be strobed to hold a particular count while the Johnson counter continues to be clocked. The decoder feeds a seven-segment bipolar output driver which can source up to 25 mA to drive LEDs and other displays such as low-voltage fluorescent and incandescent lamps.
评论(1)
发评论
fanyi1991 2011-04-20
0 回复 举报
好,非常好,我支持!^_^ 收起回复
下载排行榜
全部1条评论
