TMS320F28033PN,pdf(Piccolo Mic
消耗积分:5 | 格式:rar | 大小:1608 | 2010-11-29
84784
分享资料个
The F2803x Piccolo™ family of microcontrollers provides the power of the C28x™ core and Control Law Accelerator (CLA) coupled with highly integrated control peripherals in low pin-count devices. This family is code compatible with previous C28-based code, as well as providing a high level of analog integration.
An internal voltage regulator allows for single rail operation. Enhancements have been made to the HRPWM module to allow for dual-edge control (frequency modulation). Analog comparators with internal 10-bit references have been added and can be routed directly to control the PWM outputs. The ADC converts from 0 to 3.3-V fixed full scale range and supports ratio-metric VREFHI/VREFLO references.
评论(1)
发评论
azhimoqingyou 2019-07-19
0 回复 举报
看看有关28033的资料 收起回复
下载排行榜
全部1条评论
