PCI9656 pdf datasheet
消耗积分:10 | 格式:rar | 大小:555 | 2008-10-13
分享资料个
Maximum PCI Bandwidth for Your 32-bit Local Bus Applications
The PCI 9656 offers flexible connectivity and high performance I/O acceleration features
to enable leading edge PCI, CompactPCI, and embedded host designs.
Motorola MPC 850/860 PowerQUICC Designs
The PCI 9656 is the perfect match for the industry leading 32-bit communication proces-
sor, the Motorola MPC 850/860 PowerQUICC. The PCI 9656 provides a direct connection
to PowerQUICC devices, enabling high-speed 64-bit, 66MHz PCI performance with its
Data Pipe Architecture? technology.
Generic 32-bit, 66MHz Local Bus Designs
The PCI 9656 provides direct connection to two generic industry standard interconnect
buses. Designers use these 32-bit, 66MHz buses for a myriad of high-speed devices rang-
ing from processors, to DSPs, to memories, to custom ASICs and FPGAs.
The PCI 9656 Data Pipe Architecture technology enables high-speed, 64-bit, 66MHz PCI
I/O with those devices.
Move Your 32-bit Local Bus Designs Up to
64-bit, 66MHz PCI Operation
As PCI evolves to meet the ever increasing I/O demands of leading edge systems, PLX
continues to provide leading edge, high performance PCI I/O acceleration solutions. Based
on the architecture of the industry-leading PCI 9054, the PCI 9656 offers a variety of
enhancements for the needs of today's telecom, networking, and I/O adapter designs:
64-bit, 66MHz PCI operation
32-bit, 66MHz local bus operation
Dynamic DMA descriptor ring management with Valid bit semaphore control
PICMG 2.1 r2.0 Hot Swap Silicon, including Bias Voltage, Early Power, 64-bit
Initialization, and Intially Not Responding Support
PCI Power Management r1.1 D3 Power Management Event (PME) generation
COLD
PCI arbiter supporting 7 external masters
Reset and interrupt pins configurable for embedded host applications
JTAG boundary scan
The PCI 9656 is register compatible with the PCI 9054, enabling easy software migration.
评论(0)
发评论
下载排行榜
