PCI9052 pdf datasheet
消耗积分:10 | 格式:rar | 大小:555 | 2008-10-13
哈哈哈
分享资料个
The PCI 9052 PCI I/O Accelerator provides low cost connectivity for PCI slave designs. It is specifically targeted at easing the transition of existing ISA designs to the more feature rich and performance oriented PCI bus. The PCI 9052 provides direct slave PCI functions by interfacing the adapter's I/O circuitry (control, address and data lines) to a host computer's microprocessor / memory architecture via the 32-bit PCI bus, which typically runs at 33MHz. The PCI 9052 is offered in a 31.2 x 31.2 mm 160-pin PQFP. This device is available in leaded and lead-free packaging.
评论(0)
发评论
下载排行榜
