NCP1575 pdf datasheet (Low Vol
消耗积分:10 | 格式:rar | 大小:666 | 2008-10-22
分享资料个
NCP1575 Low Voltage Synchronous Buck Controller with Adjustable Switching
Frequency
The NCP1575 is a low voltage buck controller. It provides the
control for a DC−DC power solution producing an output voltage as
low as 0.980 V over a wide current range. It contains all required
circuitry for a synchronous NFET buck regulator using the V2
control method to achieve the fastest possible transient response and
best overall regulation. The NCP1575 operates at a default switching
frequency of 200 kHz, but switching frequency is user−programmable
with an additional resistor between ROSC and ground. This device
provides undervoltage lockout protection, soft−start, and built−in
adaptive nonoverlap and is assembled in an SOIC−8 package.
The NCP1575−based solution requires a bias supply of 12 V, and it
can convert from a bulk power supply ranging from 2 V to 12 V.
Conversion from bulk supplies greater than 7 V is best accomplished
by using an external doubler circuit to raise the enhancement voltage
for the external NFET switches.
评论(0)
发评论
下载排行榜
