AME8500 pdf datasheet (mProces
消耗积分:2 | 格式:rar | 大小:333 | 2008-12-01
张燕
分享资料个
The AME8500 family allows the user to customize the
CPU reset function without any external components.
The user has a large choice of reset voltage thresholds,
reset time intervals, and output driver configurations, all
of which are preset at the factory. Each wafer is trimmed
to the customer's specifications.
These circuits monitor the power supply voltage of mP
based systems. When the power supply voltage drops
below the voltage threshold a reset is asserted immediately
(within an interval TD1). The reset remains asserted
after the supply voltage rises above the voltage threshold
for a time interval, TD2 . The reset output may be either
active high (RESET) or active low (RESETB). The reset
output may be configured as either push/pull or open drain.
The state of the reset output is guaranteed to be correct
for supply voltages greater than 1V.
Space saving SOT23/TSOT-23 packages and
micropower quiescent current (<3.0mA) make this family
a natural for portable battery powered equipment.
评论(0)
发评论
下载排行榜
