MAX1316, MAX1317, MAX1318 pdf
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-02
分享资料个
The MAX1316–MAX1318/MAX1320–MAX1322/MAX1324–
MAX1326 14-bit, analog-to-digital converters (ADCs) offer
two, four, or eight independent input channels.
Independent track/hold (T/H) circuitry provides simultaneous
sampling for each channel. The MAX1316/
MAX1317/MAX1318 have a 0 to +5V input range with
±6.0V fault-tolerant inputs. The MAX1320/MAX1321/
MAX1322 have a ±5V input range with ±16.5V fault-tolerant
inputs. The MAX1324/MAX1325/MAX1326 have a
±10V input range with ±16.5V fault-tolerant inputs. These
ADCs convert two channels in 2μs, and up to eight channels
in 3.8μs, and have an 8-channel throughput of
250ksps per channel. Other features include a 10MHz
T/H input bandwidth, internal clock, internal (+2.5V) or
external (+2.0V to +3.0V) reference, and powersaving
modes.
A 16.6MHz, 14-bit, bidirectional, parallel interface provides
the conversion results and accepts digital configuration
inputs.
These devices operate from a +4.75V to +5.25V analog
supply and a separate +2.7V to +5.25V digital supply,
and consume less than 50mA total supply current.
These devices come in a 48-pin LQFP package and operate
over the extended -40°C to +85°C temperature range.
Applications
Multiphase Motor Control
Power-Grid Synchronization
Power-Factor Monitoring and Correction
Vibration and Waveform Analysis
评论(0)
发评论
下载排行榜
