DS1821 pdf datasheet (Programm
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-08
王毅山
分享资料个
The DS1821 can function as a standalone thermostat with user-programmable trip-points or as 8-bit temperature sensor with a 1-Wire digital interface. The thermostat trip-points are stored in nonvolatile memory, so DS1821 units can be programmed prior to system insertion for true standalone operation.The DS1821 has an operating temperature range of –55°C to +125°C and is accurate to ±1°C over a range of 0°C to +85°C. Communication with the DS1821 is accomplished through the open-drain DQ pin; this pin also serves as the thermostat output.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
