MAX6672/MAX6673 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-08
1123127317
分享资料个
The MAX6672/MAX6673 are low-current temperature
sensors with a single-wire output. These temperature
sensors convert the ambient temperature into a 1.4kHz
PWM output, which contains the temperature information
in its duty cycle. The MAX6672 has an open-drain
output and the MAX6673 has a push-pull output.
The MAX6672/MAX6673 operate from 2.4V to 5.5V with
a maximum supply current of 150μA. Both devices feature
a single-wire output that minimizes the number of
pins necessary to interface with a microprocessor.
The MAX6672/MAX6673 are available in 5-pin SC70
packages.
Applications
Industrial and Process Control
HVAC
Automotive
Environmental Control
Isolated Temperature Sensing
评论(0)
发评论
下载排行榜
