RT9168/RT9168A pdf datasheet (
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-11
分享资料个
The RT9168/A is a 200mA/500mA low dropout and
micropower regulator suitable for portable applications.
The output voltages range from 1.5V to 5.0V in 100mV
increments and 2% accuracy. The RT9168/A is designed
for use with very low ESR capacitors. The output remains
stable even with a 1μF ceramic output capacitor.
The RT9168/A uses an internal PMOS as the pass device,
which does not cause extra GND current in heavy load
and dropout conditions. The shutdown mode of nearly
zero operation current makes the IC suitable for batterypowered
devices. Other features include current limiting
and over temperature protection. The SOT-23-5 and
SOP-8 packages are also available for larger power
dissipation and design flexibility.
评论(0)
发评论
下载排行榜
