RT9186/RT9186A/RT9186B pdf dat
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-11
分享资料个
The RT9186 is a low-dropout linear regulator providing up
to 500mA load current with 160mV dropout. It is especially
designed for the application of portable and smart handheld
device.
The RT9186 operates from 2.5V to 5.5V supply. The
internal P-MOSFET pass transistor allows the regulator
to work with 190mA low quiescent current. Its preset output
voltage version covers the most frequently used values,
including 1.8V/2.5V/3.3V. Output voltage can also be
adjusted via the ADJ pin for those other than the preset
values.
With only 0.1mA required in the shut down mode, one
enable pin is able to control output on/off. RT9186A
contains PGOOD function. On the other hand, RT9186B
contains RST function with 6ms (typ.) time delay.
评论(0)
发评论
下载排行榜
