24c08 CMOS I²C 2-WIRE BUS
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-12
分享资料个
The Turbo IC 24C08 is a serial 8K EEPROM fabricated with
Turbo’s proprietary, high reliability, high performance CMOS
technology. It’s 8K of memory is organized as 1,024 x 8 bits.
The memory is configured as 64 pages with each page containing
16 bytes. This device offers significant advantages
in low power and low voltage applications.
The Turbo IC 24C08 uses the I²C addressing protocol and
2-wire serial interface which includes a bidirectional serial
data bus synchronized by a clock. It offers a flexible byte
write and a faster 16-byte page write.
The Turbo IC 24C08 is assembled in either a 8-pin PDIP or
8-pin SOIC package. Pin #1, #2 and #7 are not connected
(NC). Pin #3 is the A2 device address input for the 24C08,
such that a total of two 24C08 devices can be connected on
a single bus. Pin #4 is the ground (Vss). Pin #5 is the serial
data (SDA) pin used for bidirectional transfer of data. Pin #6
is the serial clock (SCL) input pin. Pin #8 is the power supply
(Vcc) pin.
评论(0)
发评论
下载排行榜
